TFTP from flash, running IOS 12.3(24)
I want to xfer the IOS image on Router L to Router B.
In global config mode on Router L, the ? facility tells me that the tftp-server command can only specify files whose URL's start with null: or nvram: or system:
Except, I want to copy the IOS image out of flash.
I haven't had a problem with this in IOS 12.2...what do I need to do here?
Re: TFTP from flash, running IOS 12.3(24)
What type of device is this?
Sorry; I was astonished to notice that I had left that info out.
It's a 2501, running IOS 12.3(24).
This sounds like a bug (or perhaps a problem with your flash). I have a few 2500s left running older code, and I am able to configure flash:. I have a few 2600s running 12.3, and I am able to configure flash: there as well. I couldn't find any matching bugs on this, so your issue may be a new one.
If tftp from flash simply isn't an option; can you recommend a workaround?
Maybe from Rxboot or ROMMON mode?
Is there a way to copy from flash into an nvram file (it does have 16MB NVRAM...) and then tftp it from there?
NVRAM isn't a workaround. It isn't nearly big enough. The only workaround I see is to copy the image from the 2501 to a host-based TFTP server, then copy that image to the new router from that host-based server.
But copy the image _how_ ??
The whole problem is that copying the image from the 2501 isn't an option; at least not via TFTP.
Router#tftp-server ?
nvram:
null:
system:
are the only options. No "flash:"
There's the rub! Any suggestions?
Copy the image using the router as a TFTP client. Say you have a host-based TFTP server running on 10.1.1.1:
Router#copy flash:c2500-i-l.123-24 tftp://10.1.1.1
Then, on the router router:
Router(boot)#copy tftp://10.1.1.1/c2500-i-l.123-24 flash:
Sorry, I misread your first sentence. If what I stated in my previous post is not an option, then would another protocol like RCP work?
I'm researching the rcp option right now - I've moved dozens of images around using tftp so it's a major comfort zone for me; only I've never used anything else; so I'm treading lightly.
RCP is a TCP transport using tcp/514. This configuration example is for CiscoWorks, but will work in general for a user named "cwuser":
username cwuser password 7 000C1C0A05
ip rcmd rcp-enable
ip rcmd remote-host cwuser 172.17.246.221 cwuser enable
ip rcmd remote-username cwuser
Thank you for that.
I'm familiarizing myself with "rsh" and the other stuff so I'll have a faint idea what I'm doing.
I will keep you updated!
Now this is interesting:
Router(config)#tftp-server flash:c2500-is-l.123-24.bin
% Invalid input detected at '^' marker.
Router(config)#tftp-server ?
null: Allow URL file TFTP load requests
nvram: Allow URL file TFTP load requests
system: Allow URL file TFTP load requests
Router(config)#tftp-server c2500-is-l.123-24.bin
Router(config)#
If "flash:" isn't allowed in the tftp-server command, how come the "^" error marker only points out the colon, not the "f?" But it catches the "c" in the filename first thing.
Is this worth analyzing, or am I just dealing with a zotzed router?
200
