Community Member
TFTP upload to Cisco 1900
I am not able to copy the configuration file from 1900 to tfpt server because there is no option in the menu to go to the commnad line (K). when I log into the switch immediately the menu appears. Is there any option to save the confirguration to tftp?
Tank you
1 REPLY
Silver
Re: TFTP upload to Cisco 1900
You can use the Configuration File Upload and Download feature to specify switch configuration commands in an ASCII file that can be uploaded to or downloaded from a TFTP server. When the switch powers up, it can retrieve its configuration from a TFTP server. check the following link for upload/download of the configuration file :
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfab.shtml#updownfile
396
