09-06-2013 08:41 AM
I have just installed cisco prime 1.2 (I used OVA file and vmware)
After installed prime I chech that he started well ( nsc stop ncs start ncs status) and all service has started
But when I acces by https and enter the login root and password, I got screen without any menu (see attachement)
Please why I don't have the normal menu
How can I fixed this issue
Solved! Go to Solution.
09-07-2013 05:22 AM
Hi Nicanor,
Prime Infrastructure supports the following browsers:
•Google Chrome—19.0 build
•Mozilla Firefox— ESR 10.x, 13.0 and 14.0
•Microsoft Internet Explorer 8.0 or 9.0 with Chrome plug-in. Native Internet Explorer is not supported.
Please try this and let us know the output.
09-06-2013 08:48 AM
Maybe try Firefox? I have had some issues with IE/Chrome and prime.
Also make sure you have flash installed
09-07-2013 05:22 AM
Hi Nicanor,
09-10-2013 10:50 AM
You are wright
I used the good version browser as you suggest and it work
