Community Member
Timezone match in templates
We have some devices configured with clock timezone UTC -5 and some devices configured with clock timezone EST -5
I need to know if there are any devices without any timezone settings. I'm using
+ clock timezone (EST|UTC) -5
in baseline templates to match both configurations. For some reason template job is unable to find any matches, even though if I run a match on + clock timezone EST -5 and it can find matches for + clock timezone UTC -5
I can match regex clock timezone (EST|UTC) -5 in raw config with a text editor. It seems that regex is correct.
What would be a fix for this problem or workaround.
1 ACCEPTED SOLUTION
Re: Timezone match in templates
You are not using regular expressions correctly. All regular expressions must be enclosed in [# ... #]. So, you need to do:
+ clock timezone [#(EST|UTC)#] -5
1 REPLY
143
