Webcast-Catalyst9k
Tomcat test
Hy,
is there any way to test db consistency in LMS 2.5?
cheers
Marc
1 ACCEPTED SOLUTION
Bronze
Re: Tomcat test
To check the consistency of the CMF, RME and ANI database, change directory to
opt/CSCOpx\objects\db\conf
and then enter this command:
./configureDb.pl action=validate dsn=cmf
do the same for rme and ani.
If the DB is ok, you should see "No errors reported."
Bronze
Re: Tomcat test
Re: Tomcat test
Thank you! That was really helpful!
But unfortunately I got following message after chen´king the RME DB.
'E:\CSCOpx\objects\db\conf>perl configureDB.pl action=validate dsn=rme
ERROR: [StandardDbUpgrade] : Database rme is not installed.'
What does it mean and what can I do? RME is installed and we're using it every day.
Thank you!
cu
Marc
Re: Tomcat test
they changed the DB name (dsn) from rme to rmeng so try it with dsn=rmeng.
You will get a list of all installed dsn by entering "perl dbpasswd.pl listdsn"
dbpasswd.pl is located at CSCOpx\bin
HTH,
MArtin
Red
Re: Tomcat test
For RME, try dsn=rmeng
123
