06-15-2009 01:31 PM
I have an issue where my CW server is pinging not only our devices on their management ips but also pinging all other interfaces those devices have. I have a firewall between my CW and the network devices and all attempts to reach addresses not belonging to the management space are dropped.
Is there a way to configure CW, and DFM, to only check the device's management ip?
I'm using LMS 2.6
Jose Ribeiro
06-15-2009 03:36 PM
Campus Manager > User Tracking > Admin > Acquisition > Ping Sweep
06-16-2009 07:41 AM
Thanks for your reply. I tried that but it did not work. I'm researching which CW module is generating the icmp traffic but no luck so far.
06-17-2009 05:33 AM
Did you check the discovery settings in the Common Services module? I figure you are using a ping sweep as well for device discovery.
/Jeroen
