topology group
I have created topology group under campus@ server and added devices manually. In network view all the devices are visible but the links between keep on disappearing. I am not able to set a proper network view for that group. Can you please guide me to figure out the problem?
1 REPLY
Re: topology group
Within Topology Groups, you may not get links between objects if no topology information can be obtained. That is, if Campus has no way of directly connecting two objects in a Topology Group, then there will be no link.
If you think links should exist, then make sure the CDP or ILMI information remains consistent between the devices in question.
96
