Topology layer2 view map will not save
Hi everyone! Been fighting an issue with LMS2.6 Topology services. When I open a topology map, all the icons are stacked in one spot. I can sort them all, but when I save the map, it doesn't save. If I close out of the application and re-open it, all the icons are stacked again. I am using IE8 with Vista.
1 REPLY
Re: Topology layer2 view map will not save
IE 8 and Vista are not supported clients for LMS 2.6. We currently do not have IE 8 support in any release of LMS, but Vista is supported in LMS 3.1. Does this problem occur if you use IE 6 on Windows 2000, 2003, or XP with a supported version of the Java plug-in?
130
