Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Traffic Generator
Hi All,
I need to know if there's a traffic generator that allows me to manipulate the payload size of the packet. The ones I've seen on the Internet are like ''Traffic'' which works only with bytes and is not that good.
I need it to test the efficiency of some protocols and for example to vary the payload of a packet from 10KB to 10MB.
Any assistance will be appreciated!!!
Cheers!
Re: Traffic Generator
Hi Collin,
I've seen iPerf but it has to be managed from the CMD and it has no help correct?
The other tool (IxChariot) is not for free...
I'll see if I find a trial....
Thanks for your help!
Yes iperf is a bit clumsy with the CLI.
124
