Traffic QOS on router with OID
Hi !
I monitor some routers with Nagios and I need to know the traffic of my QOS. I have found this two OID :
cbQosCMPostPolicyBitRate 1.3.6.1.4.1.9.9.166.1.15.1.1.11
And
cbQosCMPrePolicyBitRate 1.3.6.1.4.1.9.9.166.1.15.1.1.7
But, when I compare with my other plugin for Nagios which display the traffic in and out of my router I see that the traffic of my qos is just for the traffic_out.
I'm more interested in knowing what is the qos' traffic of my router for the traffic_in!
If there is another OID i'm interested because I haven't found it!
Thanks a lot,
Re: Traffic QOS on router with OID
Nobody for helping me? :)
Up?
Blue
Well, it depends on how you applied your QoS policies on the interface(s), e.g.:
Interface GigabitEthernet 10/1
service-policy [ output | input ] "policy-map-name"
When I use this oid : "policy-map-name" I have 2 responses :
"Wan"
"ethernet"
so my output is "wan" and input is "ethernet".
But how can I find my Qos traffic for this TWO interfaces?
Thanks a lot for your answer :)
The result of the command is :
SNMPv2-SMI::enterprises.9.9.166.1.6.1.1.1.1063 = STRING: "WAN"
SNMPv2-SMI::enterprises.9.9.166.1.6.1.1.1.1073 = STRING: "ETHERNET"
But when I search the cbQosCMPostPolicyRate I have :
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.11.1089.1093 = Gauge32: 262000
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.11.1089.1103 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.11.1089.1109 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.11.1089.1115 = Gauge32: 6000
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.11.1089.1119 = Gauge32: 271000
And this is only for the traffic out
How can I use my previous values (1063 and 1073) to get the traffic in of my qos?
up? :)
Bronze
As yjdabear stated,
This depends on the direction you have the QoS applied. If the policy is applied outbound: service-policy out, then you will be given the QoS rate for outbound traffic. If your other interface doesn't have a QoS Policy applied to it, you're not going to get anything.
810
