Community Member
Trial version of CiscoWorks LAN Management Solution
Hi, I would like to Know if and where is possible to get a trial version of CiscoWorks LAN Management Solution?
Bronze
Re: Sebastiao Miranda
You can download a trial here:
http://www.cisco.com/cgi-bin/tablebuild.pl/lms301
Support - Tools & Resources - Download Software - Routing and Switching Management
Community Member
My intention is use it in a costumer. So, I could use it up to 90 days?
Bronze
Yes, that's right.
The trial works for 90 days. After that you can upload a valid licence file and use the application without a new installation.
2096
