06-10-2010 09:15 AM
I'm attempting to add an Ad Hoc Target to IPM to measure performance between our network and a server. It is pretty self explainitory in IPM on how to add a new target. I've gone through the process of clicking on "Add Adhoc Target", I put in the IP address, and clicked ADD. IPM gives me a message saying it has been added successfully. However, when I go back into the Devices section of IPM it is not listed under the AdHoc Target group. It isn't listed under All Devices either. Any thoughts???
-tom
Solved! Go to Solution.
06-15-2010 01:49 AM
We also can't add ad-hoc targets anymore in our lab. This used to work.
We did install various campus manager and RME patches recentlty. I cannot confirm this, but I'm wondering if those patches didn't "influence" the workings of adding a ad-hoc target for IPM.
In any event, we did find a work-around.
Use the IPM CLI function:
Usage: ipm addadhoctarget -u userid -p password [-m email] {-device deviceip | hostname} [-input argumentFile]
example:
C:\Program Files\CSCOpx\bin>ipm addadhoctarget -u admin -p admin -device 10.1.2.31
* Warning * The -p option is highly insecure and *not* recommended.
* Warning * See -u option for more details.
SUMMARY
Successful: ipm addadhoctarget
At least this way you get to add the ad-hoc targets.
cheers
Pierre
06-11-2010 12:05 PM
Yeah, this interface is pretty straight-forward. I certainly cannot reproduce. What browser are you using? Exactly what are you specifying as your target device? What errors do you see in ipmclient.log after adding the adhoc target?
06-14-2010 01:48 PM
Joe,
I have tried using IE8 and IE6 browsers. I am specifying an IP Address as my AdHoc device. I only put "10.11.21.31" into the field. I tried again today and found the following in the ipmclient.log file:
[ Fri Jun 11 14:43:37 CDT 2010 ],INFO ,[TP-Processor6],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,303,Adhoc devices to be added by admin [ Fri Jun 11 14:43:37 CDT 2010 ],INFO ,[TP-Processor6],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,329,Adding the valid adhoc devices of Size 1 into IPM [ Fri Jun 11 14:43:37 CDT 2010 ],INFO ,[TP-Processor6],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,339,Added, 1 adhoc devices into IPM [ Fri Jun 11 14:44:51 CDT 2010 ],INFO ,[TP-Processor5],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,303,Adhoc devices to be added by admin [ Fri Jun 11 14:44:53 CDT 2010 ],INFO ,[TP-Processor5],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,329,Adding the valid adhoc devices of Size 0 into IPM [ Fri Jun 11 14:44:53 CDT 2010 ],INFO ,[TP-Processor5],com.cisco.nm.ipmng.devicemanager.ui.action.DCRDevicesAction,addAdhocDevices,339,Added, 0 adhoc devices into IPM
I do not receive an error message. IPM tells me the device was added successfully, but it still doesn't show in the list.
-tom
06-14-2010 11:19 PM
My guess is that the target you're trying to add is already in DCR. This could happen if the LMS server ins integrated with ACS. If so, check the Common Services > Device and Credentials > Reports > Devices not configured in ACS report to see if the targets are listed there.
06-15-2010 01:49 AM
example:
SUMMARY
cheers
Pierre
06-15-2010 06:14 AM
Thank you Pierre. The CLI option worked perfectly.
Like you, I have LMS updated with all recent updates. The OS used is Win2003 Server SP2. It is set to automatically update. Perhaps a Windows or LMS update is not compatible.
06-15-2010 09:13 PM
This shouldn't be required. If ACS is not involved, enable IPMCLIENT debugging under IPM > Admin > Loglevel Settings, then try and add an ad hoc
target in the GUI. Then post the ipmclient.log.
06-16-2010 06:25 AM
06-16-2010 10:50 PM
I'm not seeing any errors here. In fact, unlike the last log, it really does look like the device was successfully added. Given this, I recommend you open a TAC service request so this can be analyzed in real time (and the database can be inspected).
06-18-2010 08:01 AM
I opened a case with TAC. They have run into a similar issue and sent me a patch. The patch name is CSCta659741.01 but is only available as a special request download. The patch fixed my problem. Thanks for all your help!
-tom
