Trouble with SNMP Monitoring
I am currently trying to set up nagios to monitor SNMP traps and to pull CPU information off of my 2610XM and am having NO Luck.
I have tried to enable every snmp-trap known to man, however when I do an snmpwalk from my server, I am not seeing the following OIDs that I need to see. Can anybody help me?
I am positive of the following
-SNMP community strings match
-SNMP configured to go to the nagios host
What command needs to be entered to send the below OIDS? And If I enter that command and they aren't showing up, what could a possible reason of why they aren't showing up be?
$oid_sysDescr = ".1.3.6.1.2.1.1.1.0";
$oid_cpu5min = "1.3.6.1.4.1.9.2.1.58.0";
$oid_tempState = "1.3.6.1.4.1.9.9.13.1.3.1.6.1";
Router#show version
Cisco IOS Software, C2600 Software (C2600-IPBASEK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 17-Nov-06 11:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 5 minutes
System returned to ROM by reload
System image file is "flash:c2600-i9-mz.124-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2610XM (MPC860P) processor (revision 1.0) with 127627K/3445K bytes of memory.
Processor board ID JAE073419B8
M860 processor: part number 5, mask 2
1 FastEthernet interface
2 Serial interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
1 REPLY
Re: Trouble with SNMP Monitoring
The OID for sysDescr is correct. You should be able to poll that assuming the community string is correct.
The oid for avgBusy5 is also correct, but this object is deprecated. While it should work, you might try .1.3.6.1.4.1.9.9.109.1.1.1.1.8.1 instead.
Provided the 2610XM has the necessary hardware (I know a 2620 does), the OID for ciscoEnvMonTemperatureState is also correct.
Now, be aware that none of these are traps. Nagios would need to POLL these objects via standard SNMP polling. There is a trap which will contain ciscoEnvMonTemperatureState, but only if there is a change in the temperature state (e.g. if the temperature goes from normal to critical). To enable that trap, you would need:
snmp-server enable traps envmon
291
