12-03-2006 10:08 PM
Hi All,
I am in the process of configuring IPSAL to measure voice and applications. I have implementer rtr in 2950 switch in two diffrent locations. I am able to view the reports for all configured ports except SMTP port 25.
I am using cisco works Internet Performance Monitor to view the reports. Any one give me some inputs regarding this to sort out this issue.
Gopal
12-03-2006 10:13 PM
How is your IP SLA operation configured? What errors do you get trying to view the SMTP report?
12-04-2006 03:03 AM
Hi Clarke,
Find the configration below..
rtr 4
type tcpConnect dest-ipaddr ****** dest-port 25 source-ipaddr ******* source-port 25 control disable
frequency 61
rtr schedule 4 life forever start-time now
While debugging I got the below error ..
Dec 4 16:19:55.822: RTR 10561: Starting An Echo Operation - IP RTR Probe MaxName source-ip=0.0.0.0(0) dest-ip=10.140.32.10(25)
Cannot connect to server
In the rarget device I have configured "rtr responder".
Advice me to resolve this issue.
Gopal
12-04-2006 08:49 AM
Did you not use IPM to configure this operation? IPM can only view operations that it configures?
Additionally, you should not use source port 25 for SMTP operations. A client will [almost] never use this as the source port. The source port should be a ephemeral TCP port or at least one >= 1024.
Assuming that 10.140.32.10 is the SMTP server configured in your operation above, it may very well be that this device cannot reach that server.
