Webcast-Catalyst9k
Tunnel L2TPV3 using Cisco Router 880
Dear Sirs, I would need to get your support as soon as possible. We need to setup a VPN using a L2TPV3 tunnel from a operation center in Spain  to Poland
The Router in Poland has this version: Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.2(4)M3
This SW version includes the feature: Advanced IP Services Feature Set ? This setting is needed to create the l2tpv3 tunnel. Is it neccessary to install any aditional software ?
 SL-880-AIS: Upgrade from Advanced Security to Advanced IP Services for Cisco 880 Data part numbers. We mail you the Product Authorization Key (PAK).
Thank you very much! Kind regards, Miguel
Everyone's tags (1)
41
