Community Member
UDP telnet tool
any tool other than port query to telnet to udp port
Community Member
Re: UDP telnet tool
Can not be telneted to UDP Port. Telnet means connection. UDP is a connectionless protocol. It doesnt initiate any connections...
Can you tell us What you wanna do exactly?
Silver
Re: UDP telnet tool
I'm not aware of any applications able to do a telnet over UDP. Ciscorouter is the only one that does.
Maybe a hacker script/application can.
Cheers,
Michel
680
