UdpJitter(codec) configuration using SNMP
Who can told me order of setting objects for UdpJitter(codec)operation?
For example following is order of setting objects for UdpJitter without codec:
rttMonCtrlAdminRttType.<index> -Integer 9
rttMonEchoAdminProtocol.<index> -Integer 27
rttMonEchoAdminTargetAddress.<index> -OctetString "05 00 00 02"
rttMonEchoAdminTargetPort.<index> -Integer 8000
rttMonEchoAdminInterval.<index> -Integer 20
rttMonEchoAdminNumPackets.<index> -Integer 100
rttMonCtrlAdminStatus.<index> -Integer 4
rttMonScheduleAdminRttStartTime.<index> -TimeTicks 1
Thanks ahead
1 ACCEPTED SOLUTION
Re: UdpJitter(codec) configuration using SNMP
You can insert the rttMonEchoAdminCodecType just before rttMonCtrlAdminStatus. However, you cannot specify rttMonEchoAdminPktDataRequestSize, rttMonEchoAdminInterval, or rttMonEchoAdminPackets if you specify a codec. See the CISCO-RTTMON-MIB for more details.
Thanks very much!
148
