Ugent Help required for installing Cisco ACS 3.3
I have a question to ask regarding Cisco ACS version 3.3 .
We are about to install the software on a Windows 2003 Server platform with the following spec:
Dual Pentium 3 - 500Mhz Xeon Processor with 1.5 GB RAM
The installation notes specify a minimum spec of a Pentium 3 - 750Mhz. I assumed that the software would operate better in a dual processor environment but this appears not to be the case. The installation notes mention that the software (ACS v3.3) doesnt take advantage of Dual Processor systems.
Would the above spec be ok to install the software or would you recommend a beefier system ? Does anyone know the roadmap for ACS, i.e will a version be released to take advantage of Dual Processor systems ?
Thanks in advance.
1 REPLY
Silver
Re: Ugent Help required for installing Cisco ACS 3.3
For best performance of the ACS server it is always recommended to stick to the minimum pre requisite. The specification that you have will work with ACS 3.3 but will not give you optimal performance.
113
