06-21-2007 10:27 PM
i telnet 2620XM and unable to connect, when i login to console its show
" Low on memory; try again later" what to do i am not able to connect both by telnet and console.
need urgent reply
thanx & Regds
Naveed
06-22-2007 12:34 AM
Hi your router may be over taxed and not be responding as quick as you expect. You could reboot and try connecting it then see if starts responding.
you can do a show proc if it starts responding to see what the proccessor utilization is.
Patrick
06-22-2007 09:31 AM
Can you ping the device, does it answer? If so, do a nmap,scan and see what ports are open, telnet port 23?
06-22-2007 06:43 PM
Naveed
Before you posted in this forum you posted the same question in the WAN Routing and Switching forum where it has received several responses. I suggest that any further discussion be consolidated in the WAN forum.
Rick
