Community Member
Unable to connect with telnet and console
i telnet 2620XM and unable to connect, when i login to console its show
" Low on memory; try again later" what to do i am not able to connect both by telnet and console.
need urgent reply
thanx & Regds
Naveed
Re: Unable to connect with telnet and console
Hi your router may be over taxed and not be responding as quick as you expect. You could reboot and try connecting it then see if starts responding.
you can do a show proc if it starts responding to see what the proccessor utilization is.
Patrick
Community Member
Can you ping the device, does it answer? If so, do a nmap,scan and see what ports are open, telnet port 23?
Hall of Fame Super Gold
Naveed
Before you posted in this forum you posted the same question in the WAN Routing and Switching forum where it has received several responses. I suggest that any further discussion be consolidated in the WAN forum.
Rick
125
