07-16-2009 03:26 AM
I am running ciscoworks LMS 3.1. We have several switches which have been removed from the network.
When i try to delete these devices from RME i get the following error message:
DM0044: None of the chosen device can be deleted as the Auto Allocation Policy is configured as Manage All Devices.
I have also removed the machines from the LMHosts file.
Any ideas how i can remove them from within ciscoworks?
Solved! Go to Solution.
07-16-2009 05:29 AM
One should generally delete devices from Commons Services' Device and Credential Repository (DCR). Go to Common Services > Device and Credentials > Device
Management.
Also, if you have integration with ACS, you would go there to start deleting devices or else there will be a discrepancy between ACS and CiscoWorks.
Hope this helps.
07-16-2009 05:29 AM
Management.
Hope this helps.
