Unable to delete devices in DFM
dionjiles
I'm running LMS 3.1 and I am unable to delete devices in DFM. The icon that is normally blue is greyed out.
I ran into the is issue with LMS 2.5.1 december updates but I can't recall what was done to fix this.
Any help with this is welcomed.
Thanks.
Joe Clarke
This is not a problem but a result of how DFM is configured. If you enable auto-management of all devices in DCR, then the delete button does not work. If you want to be able to delete devices from DFM alone, you must disable synchronization with DCR under DFM > Device Management > Device Import.
Joe Clarke
Thanks....resolved my issue.
