unable to read shadow configs with notepad
Since upgrading to LMS 2.5, RME 4.0 (Window Server 2003), we have a problem reading shadow files with notepad, like the C/R is missing. The config is virtually one long line. We don't think there have been any usoft changes. Has anyone else seen this problem?
Red
Re: unable to read shadow configs with notepad
Can you open them successfully using Wordpad?
This looks like CSCsb23710:
Shadow directory does not contain carriage return
This is fixed in RME 4.0.3
Yes, the files open with Wordpad. However, we use Sentinal software to examine the files and build network maps, etc. It will NOT use Wordpad. Both sites we have upgraded to LMS 2.5 have the issue. It does sound exactly like CSCsb23710 but that is for Solaris. And I assume we are RME 4.0.3 because I installed the lms25_dec2005_update. Any help appreciated.
110
