Unconnected Devices in CM Topo Services
Can anyone tell me why I might see a device as unconnected in Topology Services > Network Views > Unconnected Devices. I know CDP has to be enabled, the devices are reachable, and has neighbors. Is there any other critera that has to be met? Everything was working fine prior to CM4.0.4. TIA!
Re: Unconnected Devices in CM Topo Services
Are the devices also showing as unknown? Do they have snmp configured and are they snmp reachable?
Campus will read the CDP tables via SNMP to show the connections
No, they're definely known. This was working prior to 4.0.4 CM patch. A mib walk shows the CDP cache knowns about it: CISCO-CDP-MIB::cdpCacheDeviceId.51.17 = STRING: TMC_SFM1.tmcaz.com <= This is one of the devices showing as unknown
Sorry, unconnected, not unknown.
have you tried deleting the unconnected device and rediscovering it?
No, because I have been told in the past that you can't do this. Maybe they misunderstood my question I don't know. Please let me know how I can do this. TIA!
Silver
It's not only the device itself that has to be SNMP readable and have CDP running.
It's also the neigbours that need to "confirm" via SNMP and CDP the connections to a device.
This means it has to show up in their neighbour table and the interfaces on both end need to make sence, e.g. not a serial on one side and a fastether on the other.
This type of problem can also come from the use of the same hostname. It then means that Campus has neighbour info from another device making the topology incoherent.
Delete the device and maybe brining it back with a different hostname may resolve this.
Cheers,
Michel
138
