Community Member
unknown devices is CW LMS 3.0
some device appears as "Unknown device" in DCR. When i look in Common services, i got a question mark icon next to the device.
Moreover, RME is not able to fetch the config. i cannot find the solution for this. thanks in advance.....
Re: unknown devices is CW LMS 3.0
What type of devices are these? What version of RME do you have? Are these devices SNMP reachable from the LMS server using the credentials configured in DCR?
Community Member
Hi thanks for your prompt response.
RME Version: 4.1.0
Yes, they are snmp reachable from server. I am having issues with these types of devices
WS-C4506-E
CISCO2821
CISCO3845-HSC/K9
I checked regards to ios version, device types but found no issues with that….
At least the 2821 should be supported in RME 4.1. However, to be sure ,please post the sysObjectIDs from these devices.
Definitely for 4506-E support you will need to upgrade to LMS 3.0.1, and update your RME device packages. LMS 3.0.1 can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 . Then you can update to the latest Common Services MDF and RME devices packages from Common Services > Software Center > Device Update.
Community Member
But i dont have issue with all the 4506-E switches , having issue with only few switches(8 to 10 out of 40).Thats why i am wondering. please clarify on this.
What are the sysObjectIDs from these devices. It will be much easier to determine accurate device support if you post those.
Community Member
These are the OID values...
wsc4506E 1.3.6.1.4.1.9.5.59
CISCO3845-HSC/K9 1.3.6.1.4.1.9.1.544
CISCO2811 1.3.6.1.4.1.9.1.576
Ah, the 4506 is running CatOS. That explains it. All of these devices are supported in LMS 3.0. they just need to be SNMP reachable.
Go to RME > Admin > System Preferences > Application Loglevel Settings, and enable DEBUG for ICServer. Delete one of the problem devices from DCR, then re-add it. Make sure RME manages the device. After about five minutes, collect and post the IC_Server.log.
Community Member
oops, i wrongly mentioned the 4506 oid. the correct one is 1.3.6.1.4.1.9.1.502. Really sorry for that.
Yes, this device is also supported. Please follow the instructions in my previous post to gather the troubleshooting data.
Community Member
Ok, i will do that. will attach the log shortly.........
Community Member
Job Results shows "device not supported" when i run Device Credential Verification(SNMP Read, Write and telnet) job for those devices... But configuration side everything is perfect.....
I wanted you to run an inventory collection job, and post the IC_Server.log. Until the device is managed by an application, it will be an unknown device, and thus not supported for credential verification.
Community Member
i have access to ciscoworks application. but i do not have the access to ciscoworks server. is there any way to capture the icsever log from application?
No. This must be obtained from the server's file system.
Community Member
Ok, i will ask my server admin to do that....
Community Member
i deleted 10.99.1.11 and readded the same.Icserver log has been attached
This sysObjectID of this switch is 1.3.6.1.4.1.9.1.875 which is not supported in RME 4.1. You need to upgrade to LMS 3.0.1, and apply the device packages as I previously stated to get support for this device.
Community Member
so it should not support all the 4506-E switches right?
Community Member
so it should not support all the 4506-E switches right?.As i told previously , i dont have issue with all the 4506-E switches , having issue with only few switches(8 to 10 out of 40)....
Any true 4506-E with this sysObjectID (1.3.6.1.4.1.9.1.875) will not be supported until you upgrade to LMS 3.0.1, and apply all of the available RME 4.1.1 device packages.
Community Member
ok. Then what about these devices
CISCO2821
CISCO3845-HSC/K9
Yes, these devices are supported as well in RME 4.1.1.
Community Member
how can i upgrade it to LMS 3.0.1. is there any documents available with guidelines.
Hall of Fame Super Silver
232
