02-21-2008 02:09 AM
in my 2501 password breaking option is disabled.
I can break the booting process and go to ROMMON and make the config register in to 0x2142. When I restart I can go to enable mode. But I can't give 'show run' or 'show start' commands.
And the moment I put the configuration back to 0x2102, it asks for the password that the previous owner has put.
Does anyone know how to solve this issue?
Thanks in advance for any advice!
Solved! Go to Solution.
02-21-2008 09:05 AM
02-21-2008 09:05 AM
02-22-2008 09:22 PM
Hi Rob
Many thanks indeed for your kind help. I got my problem solved.
Take care
Chris
