Upgrade ASA with LMS 3.1
Hey,
is there a way to upgrade both, asa ios and pdm file, with Cisco Works?
I can't add the pdm file to the software repository.
If I try it with a NetConfig job, the job will fail with the message "Cause: connect timed out. Insufficient no. of interactive responses(or timeout) for command "copy tftp://IP/asdm-file.bin disk0:/asdm-file.bin<R><R><R>"
Thx,
Patrick
1 REPLY
Re: Upgrade ASA with LMS 3.1
For the ADSM, you will need to use Netconfig. This functionality should work provided your job timeout is sufficiently high. Exactly what prompts do you get when executing this command manually on the ASA?
118
