Community Member
Upgrade flash card 3550?
Ciscoworks recommends I upgrade one of the flashcards on my 3550 switches before an IOS upgrade can happen. I don't find anthing on this site regarding upgrading the flash memory on the 3550. My config shows this is onboard memory so I assume I do not have the option to upgrade. Can someone confirm this?
1 REPLY
Silver
Re: Upgrade flash card 3550?
If you have a PCMCIA slot you can still install a new flash on to the device. What is the firmware running on the 3550 switches? Is this a new installation.
157
