10-12-2017 11:52 AM - edited 03-01-2019 06:11 PM
Hi guys,
I already installed LMS 4.2 and added the licenses inside it and I decided later to upgrade it into 4.22..and I have the iso file ..
Can I install LMS 4.2.2 from cratch and move my licenses to it?
Or I have to make upgrade procedure?
thanks for eveyone
MK Saeed
10-12-2017 07:43 PM
Upgrade from 4.2 to 4.2.2 is simple and best done inline (on the same host).
If you decide to change hosts and rebuild on a new one then you will have to rehost your licenses (open a TAC case) as they are tied to the host's UDI or vUDI ((virtual)Universal Device Identifier - a unique value for each host)
10-15-2017 12:09 AM
Hi Marvin,
Could you guide me to good steps for upgrading through inline.
10-15-2017 04:28 AM - edited 10-15-2017 04:33 AM
Unless you have some specific reason for needing only 4.2.2, you should upgrade directly to the most recent release - 4.2.5.
Instructions for doing so are in the release notes here:
If you navigate up one level in the documentation tree you can find similar notes for the other releases.
Once you have successfully upgraded you should also install all the current available device packages. The procedure for this is in the Admin Guide as linked below:
10-15-2017 05:04 AM
Do my licenses will work with 4.2.5?
10-15-2017 07:09 AM
Your licenses will remain in effect and valid as long as you keep your LMS on the same host.
