upgrade ios with ciscowork
guygez321
Dear professionals,
I have RME 3.3, and I tried to upgrade cat3500xl and 2900xl and I got this message:
Loading image file to flash device : c3500xl-c3h2s-tar.120-5.WC13.tar --> flash:c3500xl-c3h2s- tar.120-5.WC13.tar
Running image will be overwritten by the new image ...
Error loading image to Flash.
Error Info Code: '4175'
Message: 'Device Error: Flash copy to/from operation failed.'
Action/Reason:
'Probable Cause: The source file size and the destination file size do
not match. Disk space on tftp root directory may not be sufficient.
Recommended Action: Verify disk space in the TFTP directoryand
retry the operation. If the problem persists, contact your technical support
representative for assistance.'
Device has been unlocked from exclusive access.
Thanks for your help.
Guy
pradeepde
Level 5
Level 5
This problem was fixed in one of the RME 3.4 IDUs. Upgrading from RME3.3 to RME 3.4 + latest available IDU could solve the problem.
pradeepde
Level 5
Level 5
Thank you for your help, I saved a lot of time.
