01-11-2008 08:07 AM
If i need to upgrade my LMS 2.5 to a higher vesion, do i need to purchase? what about the updates? I need to resolve the issue of accessing devices using SSH on RME.
Solved! Go to Solution.
01-11-2008 08:58 AM
You can upgrade to LMS 2.6 for free at the following link, provided you have access:
http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml
There is a cost associated with going to LMS 3.0 though, so you might want to contact your account rep or reseller about the cost.
01-11-2008 08:58 AM
01-12-2008 04:54 AM
Thanks alot.
01-13-2008 10:38 PM
LMS 2.5 can manage your devices via SSH.
To access the devices via SSH you may also need to upgrade the devices involved. Newer IOS, more RAM, more flash, configuration changes and downtime for implementation.
SSH access is not just a management side thing, in fact getting all devices SSH ready, might be even more expensive then the LMS upgrade.
Cheers,
Michel
