Webcast-Catalyst9k
Upgrade steps from LMS 2.5 to 2.5.1
Going to do a clean install of LMS 2.5 on a windows 2003 box. In order to update LMS 2.5 to the latest version, will applying the december 2005 patch cover that or do I need to apply other patches before the December patch?
Red
Re: Upgrade steps from LMS 2.5 to 2.5.1
You may go directly from LMS 2.5 without any Service Packs to LMS 2.5.1 (December 2005 updates).
You may go directly to LMS 2.5.1 and you may have a working system.
I had some trouble with dec2005updates on different systems.
Before installing the update I would stop all processes manually (net stop crmdmgtd or /etc/init.d/dmgtd stop) and on windows tftp,syslog and rcp services as well. I think there were problems that the SP install prcocess could not access some files.
MArtin
I tried to perform the update from 2.5 to 2.5.1 on a Windows 2003 server and it fails at 47% each time.
It gives the error message
"An error occurred during the move data process: -105"
Component: pm
Gile Group:
File
Can anyone help?
Component: pm
Gile Group:
File
Can anyone help?
I was having error "move data process: -105".
I found the fix to this is as follows:-
- Set Daemon Manager to Manual Startup in Control Panel->Admin Tools->Services, then reboot the server.
- Install\Upgrade version 2.5.1 and this should work ok.
- After a successful installation and reboot, chnage the Daemon manager service to Automtic in Control Panel->Admin Tools->Services.
- Reboot the server again and you should be fine. It worked for me
hi,
it works for me too =)
139
