Upgrade to CW 2.5 (CWLMS-2.5-MR-K9)
I'm preparing to install the Ciscoworks upgrade 2.5 (CWLMS-2.5-MR-K9) but notice that in the box there are only 4 CDs (RME, DFM, Campus and IPM) and no single one labeled Common Services. Should I have a 5th CD titled Common Services or this application is included in some of the previous 4 CDs?
My last concern regards whether this package (CWLMS-2.5-MR-K9) is just the upgrade, so I need to install first 2.2, or it accounts for the full version.
Thanks.
1 REPLY
Re: Upgrade to CW 2.5 (CWLMS-2.5-MR-K9)
You should have a separate cd for common services, so you might want to go back to your acct team or vendor to get the cd that is missing.
If you purchased LMS 2.5 as an upgrade it means you will need to have the old version somewhere to validate the license. You can install 2.5 from scratch, but will need to validate your license from another 2.2 server or the original 2.2 cd's.
157
