Upgraded to 12.4-9.T2 & 12.4-11.T and there is no NTP Syntax
Has anyone ran into this as well?
Is there a different/new command?
The I am using ntp to synch the time for all syslogs.
1 REPLY
Re: Upgraded to 12.4-9.T2 & 12.4-11.T and there is no NTP Syntax
I upgraded my 7206 from 12.4(9)T to 12.4(11)T yesterday (ADVENTERPRISEK9 feature set for both versions). I still have all the ntp commands. From what feature set did you upgrade? What feature set are you running now?
92
