Community Member
Upgrading 3750 stacks using LMS
Hi All,
While attempting to utilise RME to upgrade IOS on 3750 stacks, I've noticed that the jobs fail when trying to upgrade the Slave switches in the stack because the Slave's flash (when = 16M) doesn't get erased (only the Master) and there's not enough room for a second image.
Does anyone know if/when Cisco will fix this? Is there a way to edit the CLI commands of these automatic jobs, in CiscoWorks, to add in the extra commands (ie, not an AdHoc job)?
Thx.
1 ACCEPTED SOLUTION
Re: Upgrading 3750 stacks using LMS
Sounds like you're hitting CSCsg64051 which is not yet fixed. Currently, there is no ETA on a solution. The workaround is to manually free up enough flash space on the cluster members then perform the SWIM job.
Community Member
Thanks Joe, thats it exactly and the workaround I've been using.
I'll monitor the bug...
Cheers
139
