upgrading ASDM
Currently we are at asa version 7.0(6) and 5.0 for the asdm
Cisco Adaptive Security Appliance Software Version 7.0(6)
Device Manager Version 5.0(6)
We would like to be at ASDM version 6.0. How do I go about upgrading. I read that we need to be atleast ASA software version 8.0. Can I go straight from 7.0 to 8.0. And Can I upgrade Asdm straight from 5.0 to 6.0??
Please let us know as we would like to take advantage of the top talker feature.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: upgrading ASDM
Shir
If you upgrade your ASA to version 8.0 then it will work to upgrade to ASDM 6.0. I have done an upgrade from 7.x to 8.x and from ASDM from 5.x to 6.x and it worked quite smoothly.
Rick
Re: upgrading ASDM
Shir
Rick
Re: upgrading ASDM
Shir
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read responses which resolved the question.
The forum is an excellent place to learn more about Cisco networking. I encourage you to continue your participation in the forum.
Rick
223
