Uploading 3rd Party Cert NOT Working Prime LMS 4.2
Hi all,
I followed the next steps but when I tried to upload the 3rd party cert into the Prime LMS using SSL Utlity Script option 5 or 6, the process is stuck. I did not get a message similar to step 4 like: "introduce the location of the certificate...."
1.-Create a CSR using OpenSSL as usual. (it always works on Cisco ISE, ACS, etc).
2.-Create the LMS Server Certificate on my local CA Server using the previous CSR.
3.-Downloaded the CA Root & Intermediate Servers Certificate (Base64 Encoded - In fact the Cisco Guide DO NOT MENTION this part, only when I ran the OPTION 4, I realized I needed it instead of DER Encoded I have been using regularly).
4.-Downloaded the Prime LMS New Certificate, again 64Base Encoded.
5.-Using SSL Utility Script, I ran Option 4 to validate the Certificates previously downloaded and the process went sucessful. No error messages.
6.-TRY TO UPLOAD the LMS and CA Server Certificates but the process is STUCK after introducing YES whe this is required.
Any ideas about this (may be is a bug or similar)?
thanks
Abraham
177
