UPMProcess down in HUM
Hi I am trying to create a poll and I am getting the following error
Cannot communicate with Poller Manager Service. Check whether the UPMProcess is down.
Re: UPMProcess down in HUM
On Windows, you can run pdshow from a DOS prompt. On Solaris, run /opt/CSCOpx/bin/pdshow.
Process= WlseUHIC
State = Running normally
Pid = 4680
RC = 0
Signo = 0
Start = 8/18/2008 10:29:36 PM
Stop = Not applicable
Core = Not applicable
Info = Started.
Process= AdapterServer1
State = Administrator has shut down this server
Pid = 0
RC = 1
Signo = 0
Stop = 9/10/2008 12:34:34 AM
Info = Server started by admin request
State = Program started - No mgt msgs received
Pid = 3864
RC = 0
Signo = 0
E:\Documents and Settings\acano>
Sorry I am new to this forums, here it is
Please post the upm_process.log and the UPMProcess.log.
here it is
Try starting UPMProcess manually using the command:
pdexec UPMProcess
ERROR: cmd failed. Server reason: Application UPMprocess is not registered. All requests to operate on this application
will be ignored.
The command is:
pdexec UPMProcess
Case is important. However, that may not bring HUM up. Instead, try restarting all of dmgtd:
net stop crmdmgtd
net start crmdmgtd
C:\Documents and Settings\net-eng>net stop crmdmgtd
System error 1060 has occurred.
The specified service does not exist as an installed service.
disregard the last message, I was in the wrong screen
I just restarted the process I am going to try again to add the Poll
I amgetting the same error again
Please post the EPMServer.log and the dfmLogs\EPM\EPM.log.
Here it is
Please post a list of your Windows services and their startup parameters.
My server guys are gone can you tell me how is the quickest way to do this?
Capture screenshots of the Services control panel.
Let me know if this works
This is fine. Now, shutdown Daemon Manager, and post the output of netstat -a -n -o -b.
Netstat
Some of the LMS processes are not stopping properly. I suspect this is due to CSCsm04957. You need to upgrade to DFM 3.0.3. In the meantime, if you reboot this server, you should get HUM to work again, but the problem will most likely return until you upgrade DFM.
Awesome, the reboot fix it, I try looking for the DFM upgrade but no luck, I only see DFM 2.X upgrade. Any ideas?
You can find DFM 3.0.3 from Common Services > Software Center > Software Update.
Please post the output of the pdshow command.
how do I do that?
I can not fit everything in here any particular one you want to see?
Redirect the output to a file, then post the file.
656
