urgent -- tacacs accounting
Hi All,
I am using tacacs+ for authentication, i already configured the cisco router and enabled accounting for commands to be logged. commands issued at privilege/config modes are being logeed perfectly but commands issued at interface level are not...
Have any one idea about the reason or some one run through the same issue.
I am attaching the configuration applied at cisco router , I would appreciate any feedback,
Best Regards,
1 REPLY
Re: urgent -- tacacs accounting
The problem might be on your command level. Bellow is a working script we setup in our network which records all commands including interfaces.
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs line
authentication enable default group tacacs+ enable
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default stop-only group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting system default stop-only group tacacs+
tacacs-server host x.x.x.x
tacacs-server timeout 3
tacacs-server directed-request
tacacs-server key xxxxx
Im sure you have seen docs on this but here is one in case.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800ca6d9.html#1019013
Hope this helps
Jorge
118
