Silver
Use of FlexConfig for unsupported commands
I want to manage an unsupported command in a class map using CSM 4.0, on an 877 router.
The original class map:
class-map match-any P2P
match protocol gnutella
match protocol edonkey
match protocol fasttrack
match protocol kazaa2
match protocol bittorrent
Under a class map there is a match statement for bittorrent. When I import this config including this command and do an initial deployment to a file CSM complains that the match bittorrent is an unsupported command. Oh, and CSM changes the orignal policy name to one of its own choosing, but I can work with that.
CSM generated class map:
class-map match-any CSM_CLASS_MAP_1
So I created a flexconfig which contains the lines:
When I deploy the new configuration to a file CSM simply adds these lines straight onto the last line of configuration, if I look at the text file it generated I end up with this line:
bridge 3 route ipclass-map match-any CSM_CLASS_MAP_1match protocol bittorrent
What am I doing wrong? The documention goes on about using scripting languages to do sophisticated manipulation of config variables, but can it do simple stuff like this?
168
