Community Member
User Tracking (C.M 5.1.1) not detecting IP Phone CCM 7.0.2
Do we need special patch ?
We have installed latest version on Campus Manager and the IP Phones desserved by CCM 7.0.2 are not detected ?
We have 2 CCM cluster, phones in CCM 4.2 are well detected.
1 ACCEPTED SOLUTION
Re: User Tracking (C.M 5.1.1) not detecting IP Phone CCM 7.0.2
Yes, you will need to enable the CISCO-CCM-MIB on your Call Manager. I believe that is done under Tool > Control Center - Feature Services on the CCM.
If you have CM 5.1.1, you should have the latest CCM support in Campus Manager. What is the sysObjectID of this CCM? Is it appearing on the Topology Map with a green Application Server icon?
Community Member
Yes Topology Map show the server in green statut.
SNMP WALK showing the SYsobjectID
RFC1213-MIB::sysDescr.0 = STRING: "Hardware:7845H2, 2 , 4096 MB Memory: Software:UCOS 4.0.0.0-9"
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::ciscoMCS7845H
Then UT should be able to find phones from this CCM. What does a walk of the ccmPhoneTable look like from this CCM?
Community Member
The following is a SNMP walk of device 10.24.192.10 starting from .1.3.6.1.4.1.9.9.156.1.2.1
SNMP Walk Output
CISCO-CCM-MIB::ccmPhoneTable = No Such Object available on this agent at this OID
Do you think I have other parameter to set in CCM ? Doesn't seem to allow access to that table !
236
