using event manager on 6513 switch
Hello everyone. Trying to create event manager event on 6513 switch IOS 12.2(33) to do rinning-config automatic back up but for some reason it does not work. Here is the set of commands:
event manager applet Archive_Configuration
event timer cron name "Archive_Configuration" cron-entry "0 1 * * *"
action 1.0 cli command "archive config"
It does not start applet. archive config works fine when triggered manually. Thanks in advance.
1 ACCEPTED SOLUTION
Re: using event manager on 6513 switch
This applet will run every day at 0100. You should be running NTP on this switch so that the internal clock is correct.
Next, your action list is wrong. The archive config command requires enable access. So, your applet should be:
action 1.0 cli command "enable"
action 2.0 cli command "archive config"
Oops, I missed enable command here. Thanks a lot for your help.
247
