07-15-2009 05:50 AM
Hi there,
we are running a Mgmt-Web-Portal based on apache.
I integrated some portlets on a special website.
This is running very well.
The only thing is that for showing up the portles on HTML-Website a proper CW2000-Login must be performed (otherwise all IFRAME-Elements where portlets are embedded show up the login box).
Is there a possiblity to check get feedback from CW2000-System if login is already done, or must be performed prior to access the portlets?
Thanks for any feedback and ideas
Lothar
07-15-2009 08:53 AM
You must pre-login to LMS (or login through the various portlets before they will show you the desired information.
07-15-2009 10:26 PM
Hi Joe,
thanks for the update.
Aren't there any possibilities for a pre-check whether sucessful login did happen in the past and a session is still active to maybe bypass login procedure.
Maybe a certain URL returning 0 for no session active and 1 for session active.
Thanks for your update
Lothar
07-15-2009 10:42 PM
If you have already authenticated, you will not see the login dialog. I don't really understand what you're asking for. We don't expose any such programmatic authentication check URL for user use.
