12-23-2008 05:26 PM
I had this working... I thought. I matched the traffic statistics on one of my Cisco ASA site-site tunnels with the OID:1.3.6.1.4.1.9.9.171.1.4.3.1.1.25.4142 (cipSecTunHistInOctets). I was real proud of myself for a few days until I checked the history and found the OID wasnt working..
After some troubleshooting I found that the last four digits (4142 in this case) change whenever the tunnel drops and re-establishes itself.
Has anyone managed to figure out a way to collect tunnel utilization history on an ASA with SNMP? Is there a different OID I can use thats based on the endpoint IP?
12-30-2008 09:52 AM
The ipsec-flow-monitor-mib should provides more detailed statistics for
ipsec tunnels:
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-IPSEC-FLOW-MONITOR-MIB.my
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/pix/pix-supportlist.html
07-21-2011 03:40 PM
Check
Advantage of VPNTTG over other SNMP based monitoring software’s is following: Other (commonly used) software’s are working with static OID numbers, i.e. whenever tunnel disconnects and reconnects, it gets assigned a new OID number. This means that the historical data, gathered on the connection, is lost each time. However, VPNTTG works with VPN peer’s IP address and it stores for each VPN tunnel historical monitoring data into the SQL server and into the RRD (Round Robin Database) file.
