UT never stop running
I have problem with my user tracking. When i start the user trackin it never stop. And i get following message in ut.log.
java.lang.OutOfMemoryError
<<no stack trace available>>
2006/05/17 10:38:31 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 531758]
Re: UT never stop running
Looks to be a memory issue with the number of devices you are trying to collect. Is this on Solaris ? Do you have a number of 3550, 3650, or 3750 series running 12.2(25)SED or earlier code?
You can try increasing the size of the ANIServer
memory:
# /etc/init.d/dmgtd stop
# cd /opt/CSCOpx/objects/dmgt
# cp dmgtd.conf dmgtd.confBAK
# vi dmgtd.conf
/^ANIServer
This will place your cursor on the line for the startup of ANIServer. The first
word on this line should be "ANIServer". Toward the end of this long line you
should see something like "-Xmx1024m". Try changing this value to "-Xmx2048m".
# /etc/init.d/dmgtd start
Run the data collection again. If it is successful, you can try stepping the
value down to say 1536m.
It's a windows installation
For Windows:
# From DOS --> net stop crmdmgtd
# Then go to c:\Program Files\CSCOpx\objects\dmgt
# Make a backup of dmgtd.conf --> dmgtd.confBAK
# Edit the dmgtd.conf with notepad
Look for the word "ANIServer" as the first
word on a line.
# net start crmdmgtd
88
