Community Member
UT not deleting old entries
I am using lms2.5 CM4.0.2 RME4.0.2
User Tracker is not deleting old entries. I have configured in UT admin a delete interval to delete entry older than 5 days, after every major aquistition. But this doesn't happen. As anyone else had this problem?
1 REPLY
Community Member
Re: UT not deleting old entries
There is a known bug. You can upgrade to LMS2.51 to fix it or contact the TAC to get the patch.
104
