UT on campus manager 4.0.4
I´ve installed the last service pack CM 4.0.4, I have a little problem, on database of user tracking does not appear entries from switch 6513 IOS all port are on vlan 1, I noticed that entries appears with incorrect device name, In Campus Manager 4.0.3 i didn´t have this problem.
For example
,00-12-79-93-c7-c0,cicredes.,10.2.1.117,10.2.0.0/22,10.2.0.9, 1/1 ,default,"25 Apr 2006, 14:10:28 CDT",
This server must be connected on interface fastether 4/24 device 10.2.0.1
So How I could resolve it ?
thanks foor your help
Re: UT on campus manager 4.0.4
What does the output of show cam dynamic show for the device? Can you also walk the BRIDGE-MIB to see if snmp is showing the entries correct.
http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_tech_note09186a0080094a9b.shtml
If the CLI and SNMP are showing entries different than UT then we know UT is the problem.
First i opened the module Device center, select the device 10.2.0.1 and when i chosee the option UT End Host Report, show me a mesaage "Device does not have any end hosts connected to it"
So I obtain the data from the web page that you mentioned, only with the information from vlan 1 on step 4 doesn´t show me anything, maybe something it´s wrong ?
But the data for vlan 205 the CLI and SNMP information are equal, so maybe UT is the problem, I attach to files with this inforation.
so Now what can i Do ?
thanks four your help
It´s strange but, in my ohter devices all the machines that belongs to vlan 1, appear on field vlan "default" and it must be said vlan 1
For example this machine belong to vlan 1.
00-12-3f-cb-ab-0a cictec185p.ref.grupo.r
ef.com 10.2.1.12 10.2.0.0/22 10.2.0.8 3/29 default 27 Apr 2006, 15:34:20 CDT
And all the ports on 6513 belongs to vlan 1, show on vlan field "default" so where is exactly the problem ?
Or Do you recommend me to unistall CM 4.0.4 and install again the last version of Cm that war working fine 4.0.3
thanks and best regards
So any idea about who can i fix the problem ??
Hi everybody, I can´t resolve my problem I was thinking that the problem maybe its the Bridge MIB.
I have two question, first when you install the last service pack of cisco works, the mibs are update ?
Its possible change the new MIB for the oldest bridge MIB, for example the MIB that was working fine on SP3
So any suggestions
The BRIDGE-MIB wouldn't change from one service pack to another, its part of the IOS. You might want to open a TAC case to troubleshoot further
Hi davistan, I am checking this problem with my cisco provider, They recommend me that its necesary to upgrade the switch, I waiting for authorization to do that.
Main while I find this Bug CSCsb97997, maybe it has relations with my problem, what do you think ?
thans four your help
best regards
manuel
Hmmm, I don't think it would be an IOS issue. Didn't this working before you upgraded the CM service pack?
yes it was working before upgrade, but Today I testing the OID with another snmpwalk sotfware using the information that you mentioned lines above and doesn´t send any information.
Or it´s possible a mistake in the OID tested in point 4 ???
176
