06-02-2009 08:49 AM
how long CM keep record for end devices.means after the last seen? I have devices removed from the network more than 20 days CM still reporting them as last seen May 1 or 2. how I can modify to purge end devices information last seen more than 10 or 20 days? UT running every 2 days the last time running was June 1st
Solved! Go to Solution.
06-02-2009 09:26 AM
The delete interval is configurable under Campus Manager > Admin > User Tracking Admin > Acquisition > Delete Interval. By default, entries are purged after 30 days after a major acquisition runs.
06-02-2009 09:26 AM
06-02-2009 09:44 AM
thanks!
