View and username
I want to assign a view to an user on my router.
First, I want to use the local database of the router.
After, I'll use a TACACS server for this.
But, I can't do the first part.
I define a view "test" in the view root.
After, I create an user "test" associated to the view "test". But when I prompt, I'm not in this view.
I have this in my configuration:
username test view test password 0 test
parser view test
secret 5 XXXXXXXXXXX
commands sg-radius include server-private
commands exec include all show dot11
I'm using IOS 12.4(6)T5 in version Advanced IP Services.
Thanks for you help
Silver
Re: View and username
I think you can restrict a user, so that he can access only one AAA client i.e. the router which you want and for that you need to implement IP based NAR (Network Access Restriction). I am forwarding you the following link for your reference which you can use to configure IP based NAR:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs
33/user/u.htm#wp272851
Thinks for your answer Irisrios but it's not what I want (I'm very difficult :) ).
In fact, I try to define a cli view to an user.
In first time, localy on the router and after with a TACACS server.
This is the doc I found:
http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b96.html
parser view test
The view is working fine when I do "enable view test".
Somebody can help me ?
parser view test
123
