Vlan inactive
I have several devices for which the vlan name is filled in as inactivexxx (with xxx the vlan number) in the UT reports.
I tried several data collections and user trackings but the problem stays.
If I walk via SNMP to the relevant fields everything seems ok:
managementDomainLocalMode : client
managementDomainName : GSKbiorix
I check a specific ifName, for instance 9/3 (ifindex 151)
vmVlan.151 is 1000
vmPortStatus.151 is active (!!!)
vtpVlanName.1000 : RIXSRV
(Platform is W2003 LMS2.6 with latest upgrades for all bundles)
TAC asked me to set up debugging, but there is no output (file stays empty). I also noticed that the UT takes always many hours to finish its job.
Does someone recognize a similar problem and can give me usefull feedback?
Thx in advance.
1 REPLY
Re: Vlan inactive
An inactive VLAN will be created in Campus if a port is found to be a member of a VLAN that is not part of the VTP domain. This could be symptomatic of an SNMP problem on the VTP server. The recommendation to enable debugging was a good one. The debugging you need to enable is core, corex, and vlad debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options. Then you will need to run a new Data Collection. The log of interest is ani.log (by default, however, you can change this under the same interface).
372
